Ana içeriğe geç
HP Photosmart printer introduced in 2010. This printer is considered ePrint capable. Has a card reader that supports Memory Stick Pro Duo, Memory Stick Pro-HG Duo, MultiMediaCard (MMC), MMC Plus, Secure MultiMedia Card, Secure Digital (SD), SDHC. An adapter is required for MMC Mobile, Secure Digital Mini, and MicroSD cards. This printer uses a 4 color semi permanent printhead.
10 Soru Tümünü görüntüle
Replacement part needed for paper output tray
The moveable stop guide which slides out from within the output try has broken. I would like to replace it. How do I do this? What is the part or part number? Where can I get this from? Thanks
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Don’t bother trying to find a tray unless you get a really good deal on the part and you actually print photos. What I’ve done on these for mine and my dad's when they inevitably broke (we didn't use them for photos) is took the trays apart, threw the 4x6 inserts out, and "fixed" it for free. This DOES remove the dedicated tray, but it works if you can forego the option and do not use 4x6 or 5x7 photo paper.
Yes, I know this is a "photo printer", but its photo printing capabilities are a joke; fine for handout photos, but you wouldn't want to use standard CMYK for photos taken with a proper Mirrorless or DSLR camera. It lacks a PK (grey) cart, which any decent photo printer has. Good ones worth using in the studio have PK and LC/LM/LY or orange inks.
The problem is there is a plastic piece in the tray that likes to snap, and you cannot get the part from HP without paying too much for plastic, or swapping the complete printer. Yes, the delete is dirty but it costs about as much as a T10 Torx driver vs a printer swap, or a new tray. Putting a drop of Super Glue on the part to keep it in place works too, but it is subpar as it is still there and the printer may still try and grab it. You want it gone, not creating the same problem later.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Andrew Gordon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 494
