Ana içeriğe geç
The ASUS Eee PC 1008Ha is a small netbook released in 2009 with a 10.1 inch display.
netbook does not turn on after memory change
I’m a computer technician
I changed the memory of 1 GB of RAM for 2 GB.
The Netbook started, but when I tried to start it again it will not startup, nor turn on the LEDs.
I tried with battery it did not start. When I turn on the charger, I hear a soft sound as if I were passing energy
What could it be? Thanks a lot for the help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The leds not lighting would normally lead me to think there is a power supply issue, but this is a laptop with an external power brick. In this case I believe you have damaged a component somewhere on the main board, most likely with ESD during disassembly. The screen lighting once after you put it back together and not coming on again supports the idea that something important blew out.
Sorry bud.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
What is debug_con ?
tarafından
i think the problem is in a ASUS Eee PC 1008ha Power Board Module
tarafından
Yorum Ekle
Are you sure you installed the correct RAM module? Crucial 2GB DDR2-800 SODIMM
Are you sure you didn’t damage one of the wires or ribbon cables as it got caught the sheet metal or screw?
At this point I think you’ll need to go back to the 1 GB module to see what happens. Did it work?
Puan 0
6 Yorum:
I agree with trying this. When you swapped the ram did you take ESD precautions?
tarafından
I tried it, it does not start, nothing works or leds nothing works, I already checked the cables and everything is connected as it should be I disassembled many and many and it had never happened to me, I did not use the crucial one, but the samsung 800
tarafından
This is not the easiest system to change RAM as you need to take so much of the system apart.
Clearly, something got damaged in the process. I think you'll need to find someone with deeper skills locally to help you.
tarafından
Dan To be honest was not the hardest I changed the ram, my whole life made repairs and this never happened, it's strange because all the cables appear to be in good condition and well connected, it might be the button that does not start but I think the leds lit
tarafından
Hi,
Did you try the old RAM back in there to see if it still worked? You didn't say
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
ricalmeida96 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 37
Her zaman: 520
