Ana içeriğe geç
1.7 GHz dual-core Intel Processor (Turbo Boost up to 2.6 GHz) with 3 MB shared L3 cache
139 Soru Tümünü görüntüle
Troubles after expensive LCD
Since the LCD has broken, I replaced it for a new one. Procedure It should have happened, but the backlight does not light up, the monitor will only display very thin. Cause and solution
If you know someone, please let me know.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you just replaced the retina panel and not the full assembly you might have misplaced the small and difficult to plug in correctly backlight flat cable. Double check your work and make sure to do it properly. If that’s correctly in place it might be the backlight circuit gone bad on the logic board.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Thank you immediately answer.
Flat cable is connected correctly. Is there a method for repairing the backlight circuit on the logic board?
tarafından
Yes, it can be repaired, but it's not a typical do it yourself job. You'll need to find somebody into microsoldering who can do component level troubleshooting and repairs.
tarafından
Yorum Ekle
Yanıtını ekle
Shigeaki Niikura sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 56
