Ana içeriğe geç
2.0GHz Intel Core 2 Duo T7500, up to 4G RAM, 15.4in TFT LCD screen, 802.11a/b/g/n WiFi, NVIDIA Quadro FX 570M (256MB) graphics
6 Soru Tümünü görüntüle
No display on laptop
There is no display occurring on my lapty screen
beep sound are as follows
oneshort beep pause three short beep pause four short beep pause three beep
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
you may have errors with two things basically Dual In-line Memory Module
and system board check them if any one will found faulty replace the part
tarafından
@nmitt start by connecting an external monitor and see if it displays anything.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
That beep code symbolizes memory failure, and or video failure.
Replacing the RAM should fix your issue.
You have 2GB of RAM preinstalled unless you replaced it.
https://www.amazon.com/dp/B00C538B56
In that link you can buy a 4GB kit, of the RAM that your laptop supports and fits. It is actually more RAM than you have now.
2GB x2 sticks. Try doing so. Pretty cheap as its old ram models. Only 17$
Could be cheaper on EBAY as well. Just makes sure it is that. (The link I provided)
PS. This should fix and boost your Laptop.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Nmitt sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 262
