Ana içeriğe geç
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
313 Soru Tümünü görüntüle
Hdd HS12UHEA extract data.
Hi there!!! I have a HS12UHE/A rev. A, i need to extract the data from the hdd and i need a device or something that works with my model of hdd. Thanks in advance.
This is my HDD:
MacBook Air (Late 2008/Mid 2009) 120 GB Hard Drive
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Just get any type of external USB hard drive and hook it up. Then either drag and drop your data of for a recoverable hard drive backup, use Time Machine. Here's a plethora of them: http://www.google.com/search?q=external+...
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
Is not a sata normal device, is a lif or zif pin. Btw the macbook is logic board broken so i can't handle starting it or whatever. Thanks.
tarafından
Dani, there are plenty of Zif-to-USB adapters out there that should work for you. If you take the Samsung model number and do a search for it, you should find what you need. Then you connect it like mayer suggest. You may need a different computer :-) to get to the actual files since your logic board is not working.
tarafından
Is a lif to usb convert i need i guess. I was asking if anybody nows one that actually works!
tarafından
Yorum Ekle
Yanıtını ekle
Dani sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 1,208
