Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
Unable to activate - error.
Trying to set up this iPhone 6s and I keep on getting this message.
Unable to Activate
An update is required to activate your iPhone.
I have put it into restore mode twice now into iTunes on my Mac and attempted to Update & Restore. Still coming back with the same thing. Haven’t tried just restoring but it’s saying it needs an update. Also has the small exclamation mark in the top left hand corner with a “No Service” sign next to it, even though it has a SIM in it.
Any help would be much appreciated.
— Sam :)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 36
13 Yorum
Iphone 6
Unable to activate
Solution
tarafından
I have no clue how on earth is this website gained enough SEO To be this high up in this search there’s absolutely zero knowledge or advice on this page is absolutely useless
tarafından
If you have a question, ask. If you have a better answer you're free to contribute, anytime. Criticism is always welcome, pointless whining is useless.
tarafından
hi
i dont active my phone
after update whit itunse back again to unable to activate your phone page
tarafından
i can't activate iphone 6s after update.unable to activate an update is recuired to active.please help me
tarafından
8 tane daha yorum göster
Yorum Ekle
11 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I think your phone not have IMEI now.... Check on Activision screen symbol “I “ ….. When you not see the IMEI is baseband problém... Without IMEI not possible
Bu yanıt yardımcı oldu mu?
Puan 12
5 Yorum:
@vojtech So, without the IMEI it's impossible to restore?
tarafından
what do you mean that there is ni imei how is it possible
tarafından
how imei not show in the iphone is it some things are missed or stolen
board
tarafından
A fault in baseband circuitry is enough to have a phone being unable to provide the associated IMEI code. Nothing to do with a stolen board.
tarafından
how solution???
tarafından
Yorum Ekle
Follow these steps:
  1. Check the list on the System Status page. If the box by iOS Device Activation isn't green, try to activate your iPhone later.
  2. If asked to enter your password as you activate your iPhone, enter the password. (A password prompt means that Activation Lock might be enabled in Find My iPhone.)
  3. Restart your iPhone (Skip since you have tried this method).
  4. If you're using a cellular data connection, connect to a reliable Wi-Fi network instead.
If you still can't activate, here's how to activate your iPhone through iTunes instead:
  1. Make sure that you have the latest version of iTunes.
  2. Check that your computer has an Internet connection.
  3. Open iTunes on your computer. With the cable that came with your iPhone, connect your iPhone to your computer.
  4. Wait while iTunes detects and activates your iPhone:
  5. If iTunes shows, "Set up as New" or "Restore from Backup," it means that iTunes activated your iPhone.
  6. If an error in iTunes says that the SIM card isn't compatible, contact your carrier.
If all of the methods not working, try to contact Apple Support.
Puan 4
Yorum Ekle
iUnable to activate related to baseband issues.If the phone fails to detect IMEI while on activating the phones.There is common problem shows on.The way of repair that problem
.1- BBPMU reball
2- Wtr problem
3- BBCPU reball
That need to hardware skill that can`t be fixed with software.
Puan 2
Yorum Ekle
Sim not valid iphone6s
Puan 2
Yorum Ekle
Here's a bypass to get more usability out of your device (not a complete fix)
https://youtu.be/3NSWsWeINC8
Puan 1
Yorum Ekle
My iPhone not activated no service
Puan 1
1 Yorum:
My iPhone no service problem not activated
tarafından
Yorum Ekle
Why showing unable to activate
Puan 1
Yorum Ekle
My iphone like this this for 1 week now i cant call nothing. and now i cant live.
Puan 0
Yorum Ekle
my iphone 6s unable to activate
Puan 0
Yorum Ekle
my problem is that my iPhone is saying unable to activate ,You iPhone could not activated because the activation server cannot be reached
Puan 0
Yorum Ekle
You have to jailbreak it with ramdisk and create new apple id
Puan 0
Yorum Ekle
Yanıtını ekle
Sam Mileberg sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 10
Son 30 gün: 50
Her zaman: 34,216
