How do I make the second monitor active if primary is down
Normally I would use Command F1 to make the external monitor active but there is no F1 key on the touch bar. Also the screen is broken so i can’t get into system preferences on the primary display. Need to turn off autoboot before putting new display on.
Bu iyi bir soru mu?
8 Yorum
Won't removing the battery prevent the Mac from turning on whilst repairing it?
[deleted] tarafından
see step #1 Step 1 Disable Auto Boot on this guide. Just trying to follow directions
MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement
mayer tarafından
I got the bottom off without activating the power on. Not easy!
mayer tarafından
@mayer I'm at a loss of understanding that removing the lower case could trigger the fastboot?
Obviously somebody did it or it wouldn't be in the guide. Lots of things get put in guides because someone had to first do it wrong.
mayer tarafından
3 tane daha yorum göster
