Ana içeriğe geç
Mayıs 2014'te piyasaya sürülen Chromebook 2; 11,6 inç ekrana, Intel Celeron işlemciye ve 16 GB SSD'ye sahiptir. XE500C12-K01US model numarasıyla tanımlanır.
How do I fix broken audio jack?
One day, I go to use my headphones on my Samsung Chromebook 2, but I am greeted with very distorted audio. I tried everything I could to try to fix it. (Wiggle the headphone jack, remove anything in the audio jack port, etc.) After a while I found out the the headphones work perfectly fine when the mic button is pressed on them. I tested another pair of headphones, and the same thing happened. It seems that whenever I use a pair of headphones with three plastic rings on the jack, the sound is very distorted. BUT, when I use headphones with only 2 plastic rings, it works perfectly fine. Any ideas?
(My headphones worked perfectly fine before, so something must have happened to my Chromebook port.)
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Fixed by bending a piece inside the jack.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Tyler Meece sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 573
