Ana içeriğe geç
The Toshiba Satellite 2-in-1 laptop has a touchscreen 4K Ultra HD screen and an Intel i7 processor. Related model numbers: P55W-C5200D and P55W-C5314.
Which part to replace?
I recently dropped my laptop which landed on the top corner of the screen. It separated at the edge and produced a multi-shadow around the whole display. After 3 days the display went completely out. The screen did not crack. I plugged it into an external monitor and it works fine. The display key only shows the external monitor no matter what I choose (PC only, extend, duplicate) so… Should I order a new screen and digitizer OR is there other diagnostics I can perform? Toshiba wants to service it. Any repair shop wants to start with a large fee to open it up. I’ve already disassembled the screen and saw no obvious wire or cable damage… Thanks in advance and Happy Thanksgiving.
Jim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
hello I’m John it sounds like the CCFL findly went out completely. take a flash light and put it up to the screen and see if you can make out an image on the screen. if so that is the problem. In your situation i would replace the screen do to the fact that the ccfl are build into the screens already it would just save you a headache to just replace the screen. ive attached a link of a good replacement information. https://www.laptopscreen.com/English/mod...
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
John, many thanks. So, after taking the screen apart, snapping it back together again, it's back, tho I've lost the very top with multiple tiny white lines (I can't see the upper panel. ) Now, the laptop doesn't recognize the HDMI...?? go figure. So, still replace the screen? Think that will allow the HDMI to kick back in?
tarafından
yes jim that might fix the problem. that's where i would start with doing.
@jimiscrazy
tarafından
Yorum Ekle
Yanıtını ekle
jim cox sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 174
