Ana içeriğe geç
Bose 3-2-1 Ev Sinema Sistemi, Bose 2.1 ev sineması serisindeki DVD tabanlı ev medya sistemlerinden oluşan bir seridir. Bose 3-2-1 Ev Sinema Sistemi 2001 ile 2006 yılları arasında satılmış olup siyah ve grafit renk seçenekleriyle sunulmuştur.
Bose AV 321 Subwoofer Not Working.
Bose Service centre says the parts are not available in India hence can’t repair. Buyers of bose are passionate about sound, difficult to just give up.
The Bass Module stopped working after a short circuit but the speakers are working.
Who would be able to fix this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
5 Yorum
Hi Puneet Rawat
What had you tried?
What issues you are having now?
like able to turn on but no sound?
tarafından
Mine is well soldered but still no sound to the sub woofer except the smaller speakers only. What could be the problem? i have changed the TDA7396 twice now but no joy
tarafından
Hi Puneet,
did you manage to fix this? I’ve got exactly the same problem. I tested all resistors and capacitors up / from TDA7396 and they seem to be fine. I also replaced the TDA7396 as you did with no sucess. I’m really lost.
Felipe
tarafından
scusate il problema e di un chip siglato A3089G
sapete dove posso trovarlo?
tarafından
checco70t: How do you arrive to the conclussion that the problem is with that chip? Also, where is this chip located? it's not displayed in the electrical part list in the service manual
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Puneet Rawat  this could be a Bass module issue on your Bose. Post some good pictures of the modules etc. with your question. That way we can see what you see. Use this guide Mevcut bir soruya görsel ekleme for that.
Here is the schematic for the module and you can start checking components with a multimeter. Let us know what you find.
Resim
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Have you checked the fuse?
From Bose Troubleshooting guide:
”AC mains power is connected by the line cord via jack J1. A slow acting fuse F1 is connected between J1 [D7] and the locking primary connector J3 (or J2 or J4) to protect against faults. A Metal Oxide Varistor (MOV) VR1 is placed after the fuse and across the line. It is used to protect against lightning strikes and other line transients. “
I did some research and it sounds like bad solder joints are common in this unit, So I would look for any cracked joints, cold solder, etc. while you are in there inspecting the fuse.
Puan 1
2 Yorum:
Mov VR1 do you know wich one can i buy
tarafından
First you should use a meter to confirm that the part(s) is(are) bad. Start by re-flowing the solder to those parts. You can also short the fuse to see if it works, but I wouldn't recommend leaving it that way.. the fuse is there for safety of you and the device.
I found that part on tessco
https://www.tessco.com/product/suppresso...
tarafından
Yorum Ekle
ciao ragazzi io ho il problema uguale non va il sub il difetto e il chip A3089G sulla scheda madre del av3-2-1 potete darmi lo schema oppure sapete che sigla a questo chip? e dove poso reperirlo?
Puan 0
Yorum Ekle
Yanıtını ekle
Puneet Rawat sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 4,586
