Ana içeriğe geç
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
160 Soru Tümünü görüntüle
Replaced logic board and still having the same no backlight issue.
Replaced the logic board in the display with no difference. Pretty sure I can rule out logic board failure. No backlight but the display still has a picture with flashlight head closely. And the camera, usb, and ethernet still work the same. The charging for the older macs still works as well. Would it be the power supply not applying power to the backlight or the LCD? I have had stints of perfect operation in short bursts regardless of which logic board, but only after lots of messing about with plugging power in and removing it. I really don’t have another resource for information like this.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Is it the controller board on the LCD itself?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The LCDs are quite common to fail on these unfortunately, so it’s likely the LCD controller board.
In cases where we have the same symptoms, we’ve found it to either be main logic board or LCD panel.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
huntertrainboy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 71
