Replacement Battery still showing wrong capacity?
I recently replaced the battery in a Galaxy S7 after seeing that the reported capacity had dropped to less than half of its design capacity (I think it was at around 1300 mAh. New: 3000 mAh). The battery life was as bad as one would expect.
However, I’m still having the same issues with the replacement battery. Various apps show a reported capacity of ~1200 mAh and the battery life is still as bad as before. Now, I could just have received a faulty part, but I doubt that. Is it possible that the Phone/Android hasn’t properly recognized the new battery and is still trying to only charge it to the old batteries capacity? I already tried fully discharging and then fully charging the phone while off, but that did not help unfortunately. Is there anything else I could do?
Bu iyi bir soru mu?
Dear Max,
Can you attach some screenshot.
i think you you replaced part also damaged one. (duplicate battery )
you can try by using new battery.
let me know the battery usable duration.
jamsheer kp tarafından
Fairly sure the battery health reported by the phone doesn't reset when you change the battery, it ends up staying the same regardless.
I tried this on a S7 edge and the reported health capacity did not change and the charging cycles stayed the same. I used the Phone Info Samsung app to read battery percentage and cycles.
Ben tarafından
Hi @benjamen50 ,
Just for my info, would clearing the cache, factory reset etc,, reset or delete the stored battery health info?
Cheers
jayeff tarafından
I had the phone factory reset before I replaced the battery so I don't think so. This was a few months ago so I don't have the phone here to try factory reset after replacing the battery.
Ben tarafından
