Ana içeriğe geç
The Alienware 17 R4 (17.3 inches) is a gaming laptop, released by Dell in 2016. (AW17R4-7000SLV-PUS)
My fan is making a loud grinding noise
My fan is making a grinding noise. I believe the bearing is bad in it as it doesn't want to spin like the other one. When I have the Bottom cover off and I turn it on, it's struggling to spin. How can I go about removing that fan and replacing it?
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @kstorm
Well, I would suggest you to follow the below link to remove the parts
Alienware 17 R4 Battery Replacement
Follow to step 23.
The fan should be holding by with some screws.
remove it and use it as a reference to compare and order replacement.
You can purchase replacement fan at ebay, aliexpress, etc
Example:
https://www.ebay.com/sch/i.html?_from=R4...
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Hi @kstorm ,
Just to add to the answer, here's a video that shows how to remove the fans.
tarafından
@jayeff thumbs up :)
tarafından
Yorum Ekle
Yanıtını ekle
Kyran Storm sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 8,075
