Cat chewed through cable below volume control. Any way to fix this?
Cat chewed through cable below volume control. Any way to fix this ?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You certainly should be able to solder it, but soldering this type of ultra-flexible wire is a bit fiddly. See https://wiki.restarters.net/Headphones for some hints. You will need some form of strain relief so that tension in the cable isn’t borne by the solder joints.
Bu yanıt yardımcı oldu mu?
It might be much easier to just buy a new cable:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 120
1 Yorum
Hi. Maybe you could solder it but it won't be easy.
Csendes Csaba tarafından
