Ana içeriğe geç
Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
164 Soru Tümünü görüntüle
What hard disks are compatible with an iMac Intel 24" EMC 2267?
Can I put any 3.5" SATA disk into an iMac Intel 24" EMC 2267, or does this model use the hard disk's builtin temperature monitoring and so need one from the same manufacturer? Will it take a 3TB hard disk? Some sources seem to suggest 2TB is the limit.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here's an excellent article on upgrading your 2009. It also has links to compatible drives: http://www.everymac.com/systems/apple/im...
The problem with changing drives is the thermal sensor. If you stay with the same "brand" of drive there should be no problem. If you change brands, you will need to change to that companies sensor. As far as I know there are three different ones, the Western Digital 922-9225, the Seagate 922-9224 and the Hitachi 922-9223
I don't know about about a three TB drive.
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
Great research +. Unfortunately your link isn't working, can you please recheck it?
tarafından
The link is good but EveryMac has been having problems with their server off and on for a week now. I can't even open their home site right now, give it an hour.
tarafından
Link replaced
tarafından
Yorum Ekle
Yanıtını ekle
axel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 7,967
