Ana içeriğe geç
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
Why does my calculator not change from a white screen
I was using one of my programs and my screen just went blank and has stayed that way. I have used numerous different methods such as holding the 2nd button, delete and On, but the screen has stayed the same. I was wondering if there is anything left that I should try ?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try reinstalling the operating system. You will need a PC with TI-Connect and the TI-84 Plus CE OS.
Hold 2nd and del, and press the reset key in the back. Then, connect the calculator to the PC, launch TI-Connect, and send the operating system to the calculator.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
You don’t need to go through a whole OS reinstall every time your calculator freezes, just press the ‘reset’ button on the back of the calculator. Your RAM will be cleared but it’s a much quicker (only takes a second to perform) and easier fix since you don’t need a separate computer to perform it.
To prevent losing data just because a program crashed, I highly suggest installing a shell (a shell is basically a program that can run other programs with added features) called Cesium. Cesium has several backup features that will restore your data if one of your programs ever crashes! The developer, MateoConLechuga (the same guy that made Oiram, ChessCE, PacMan CE and numerous other popular calculator games) has an information thread about the shell here and a download to the shell here.
Reinstalling the OS is certainly a good thing to know how to do however, I don’t suggest doing it unless your calculator still doesn’t work after resetting the RAM.
P.S. if you ever encounter any other issues with your calculator, there’s a guide here on iFixit that should help you fix most issues!
Puan 0
Yorum Ekle
Yanıtını ekle
Anvay Pethkar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 5,811
