Ana içeriğe geç
iPad Mini 4— A1538 modelinin Wi-Fi versiyonu için kılavuzlar. 9 Eylül 2015'te duyurulan iPad Mini 4, iPad Mini 3 modelinin yenisidir.
97 Soru Tümünü görüntüle
Beats Headphone Jack stuck
The headphone plug was bent a bit, when I went to put the plug in it went in swiftly and then when I pulled it out, the beats solo 3 headphone wire cord plug got stuck. I have tried everything and nothing has worked. Is there any way that I can get it out. I have the Beats solo 3 and The Ipad is the Ipad mini 6th generation. And when I go to listen to music without the headphones no sound comes out because the ipad registers it has headphones on
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi,
If a portion of the headphones are stuck in the jack you can try to delicatly remove them using this tool GripStick Headphone Plug Extraction Tool . However you need to be careful doing thiis. If you cannot remove the jack using this method then the headphonje jack would need to be replaced which is this part iPad mini 4 (Wi-Fi) Headphone Jack .
It might be worthwhile seeking out your local repair shop if you do not feel you are able to preform the repair yourself.
Kind regards
Matt
GripStick Headphone Plug Extraction Tool Görseli
Ürün
$19.99
iPad mini 4 (Wi-Fi) Headphone Jack Görseli
Ürün
$9.99
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Not Brendon Urie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 207
