Ana içeriğe geç
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Soru Tümünü görüntüle
iPhone restarts when plugged in
Trying to make repair iphones for friends/relatives as a hobby. Encountered this problem with an i7 Plus. Whenever it’s plugged in it will restart after a few minutes. Doesn’t matter if it’s connected to pc or outlet. Tried different cables and restoring in DFU was succesful. Can’t get in the device to test more like sound etc with headphones, because it’s icloud locked, and she would come tomorrow. Is this a charging IC problem? Device got dropped in the toilt btw lmao
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Could be a charge port issue, If it doesn’t work after you get passed the iCloud lock, you probably will need to open the phone and let everything dry, then proceed to clean every component with 99% isopropyl alcohol. After this, replace the charge port.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Replaced dock and still the same problem. It also happens when it's only plugged in with the lighting port side
tarafından
Yorum Ekle
Yanıtını ekle
KWH sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 256
