Ana içeriğe geç
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
86 Soru Tümünü görüntüle
IOS 12.1.1 - Unable to use iPad - Activation Problem- iPad Model Prob.
Hey!
I recently encountered a problem with my iPad Air 2 (Cellular+Wi-Fi A1567) after restoring to the latest iOS 12.1.1. My device could not be activated because the activation information is invalid in iTunes. So now my device a not usable, I couldn't activate using WiFi as the antenna has broken.
What I found when I was playing around:
  • iTunes, the "Model Identifier" Was wrong as it shows iPad5,3 instead of iPad5,4 (which is mine)
  • Under "Regulatory" there it also displayed the wrong model number(A1566 EMC 2822)
Please see the images(https://imgur.com/a/4yBr4Zt) for more information(Sorry i can't get the picture of the back of the iPad)
I tried the iTunes restore & update function in both recovery mode and normal mode.
Is there a fix for that?
Apple repair cost me $400+ in my country which is going to cost me an arm and a leg.That's why asking for help here.
Thank in advance!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum
Hi, the first question should be what model of iPad do you have? Do your iTunes is updated? Do you have backup copy of all the data? Did iTunes show you error code if yes wich number? Did you try another lightning cable and usb port? Because if is in recovery mode there is a problem with the iOS and hope you have a copy of the iPad on iTunes or iCloud.
Try this app to exit the recovery mode :
https://www.tenorshare.net/ads/reiboot.h...
If you see here there is a list of devices that can be updated to iOS 12.1.1.I think that you can check the models and confirm you model.If right now the iPad is in recovery mode and you don;t have a backup you can try two things:
https://support.apple.com/en-us/HT209340
Any help let me know
tarafından
Your hardware markings are telling you have a iPad Mini 4 (Cellular/WiFi) and the 3rd image is telling us you have a iPad Mini 4 (WiFi only). So clearly this is not a iPad Air2
tarafından
@danj Sorry about that as i had both my ipad air 2 and ipad mini 4 having the same problem.I’ll get that image fixed
tarafından
@danj Here are the new images. https://imgur.com/a/4yBr4Zt
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
First of all make sure iTunes is up to date and try activating again.
Try updating the iPad using 3Utools (iOS 12.1.1 is the latest version at the moment). Looking from the model number from back of iPad from your photos the iPad in question is a iPad Mini 4.
Bu yanıt yardımcı oldu mu?
Puan 2
9 Yorum:
Alright I’ll try updating using 3UTools and please review this set not new pictures.Apparently i messed up with another post about the links.Cauz both my devices are having problems.
tarafından
tarafından
@benjamen50 Ive tried to activate the ipad using 3UTools but it said operation failed or something like that.After flashing back to 12.1 or on ios 12.1.1
tarafından
Are both these iPad's the cellular model by any chance? These are ones with the Sim card tray in them.
Check if the 15 digit IMEI number is being displayed in 3utools when they are plugged in.
If not, apple won't let you activate the iPad due to a hardware fault which when IMEI is not displayed it's basically a paperweight.
tarafından
@benjamen50 The ipad air 2 does have a sim tray but when its plug into 3uTools it shows the imei n/a even with sim and no sim
tarafından
4 tane daha yorum göster
Yorum Ekle
Hong, as Ben said, it is best to attempt a restore using 3U Tools. While 3U may also fail to restore your device, at least it will provide more information. Most likely, 3U tools is going tool fail somewhere around 80% when it is flashing the modem firmware. This is an indication that the modem hardware is faulty. Modem issues are responsible for many of the iTunes activation issues, though more often with iPhones. If it is a modem failure, they are among the most difficult motherboard repair jobs. You would need to find a local repair shop that is experienced in microsoldering. Apple may still be the better option at this point. Since Apple is helps to solve this issue, they would immediately give your a new iPad for your $400. The local shops will need days or weeks for an actual repair and $150-300 would be a fair price.
Puan 1
1 Yorum:
While attempting to restorw it ipad it din’t fail on 80% but it completed fully restoring it so I don’t think its a modem failure,but might it got to do with wifi?As it was broken.
tarafından
Yorum Ekle
I have the same issue with an iPad Air 2 Wifi+Cellular. Apple support was a complete waste of time
Puan 0
1 Yorum:
Apple support is kinda useless.
tarafından
Yorum Ekle
op did you find a solution after all?
Puan 0
Yorum Ekle
Yanıtını ekle
Honghongleong sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 3,812
