Ana içeriğe geç
Dell Inspiron 17 5000 Series sticker (2018 Model) Exact model can be determined at Dell Support using the Service Tag
only keyboard replace on dell inspiron 17 5770
can you only replace the dell inspiron 17 5770 keyboard?
Bu iyi bir soru mu?
Puan 1
1 Yorum
Can you provide the service tag so I can find you the correct part?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Raymond Bernard, yes it can be done. Download the SM for your computer from here It’s not easy but possible.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
SM only covers palmrest/keyboard replacement. Not keyboard removal//install of palmrest. Welded in?
tarafından
Yorum Ekle
Yes, depending on how you define 'only'. The keyboard and palm rest are pretty much integral, you need to melt plastic tabs to replace 'only' the keyboard. I have replaced my 5770 keyboard. The repair manual is still (11/2024) available here: https://dl.dell.com/topicspdf/inspiron-1...
Essentially you disassemble the computer from the bottom. The manual explains the procedure step-by-step. For me, the hard part was popping the base cover, even starting at the corner as directed; it took more force that I expected. The second time I opened the case to upgrade the network card it went quickly.
Puan 1
Yorum Ekle
Yanıtını ekle
Raymond Bernard sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 1,163
