Ana içeriğe geç
Sony Computer Entertainment tarafından üretilmiş bir oyun konsolu. PS4 olarak da bilinir. İlk olarak 20 Şubat 2013'de duyurulmuş ve 15 Kasım 2013'te satışa sunulmuştur.
1697 Soru Tümünü görüntüle
My playstation turns on, it beeps and the light appears then its off
it turns on for like a second then turns right off then you cant turn it on again unless you turn the power off at the wall and press the ps button on your controller.
please help
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Kris. Does the Console have any notable history of drops or of water damage? Are the vents filled with particularly heavy deposits of dust? Any of these answers may point closer to a solution, but PS4 repair can be pretty open-ended if the cause is unknown.
If you have hours, and I mean many hours of spare time and would like to troubleshoot this yourself, I recommend watching some of the PS4 YouTube videos by Andrew Paul. You will also need to get yourself a set of security torx screwdrivers to even begin any PS4 disassembly.
It definitely is worth testing a new power supply on your console, if only because so few screws are required to swap the PSU and you don't have to take out the motherboard to get to it. The power supply is not *very likely* though. A dead power supply would mean no light and no beep. So in your case, it could be a failing power supply. Maybe you can purchase a new PSU from a seller with a good return policy…
In my experience, consoles like yours usually have a complex motherboard problem. However that's where 50 hours of free Andrew Paul videos come in handy!
If you don't want to deal with this yourself, call around to the local computer repair shops and cell phone repair shops specificly asking if they work on a lot of PS4's. You don't want someone with no experience simply taking a heat gun to the motherboard “because they saw it in a video". That type of troubleshooting can only make a board unrepairable. In most cities, the CPR Cell Phone Repair franchises either fix PlayStation 4 in house, or they escalate the ticket and ship them in to CPR corperate.
Just keep in mind a few things: you can go on OfferUp or Letgo to buy a used PS4 for only $150-200 if repair is too much trouble. If repair is too costly, you may be able to sell your dead PS4 to the shop for $25-$50. If the motherboard really is dead, don't expect a shop to offer you a lot of cash for the box. It may have a lot of $50 parts inside, but they have no way of knowing the history or condition of those parts or if they will actually need them in the future. Take whatever cash you can get if it really isn't fixable.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
it's cheaper buying a new one rather than fixing it
the labor costs more than the parts are actually worth
costs around $300-$400 getting it fixed
tarafından
thank you for your help, greatly appretiated
tarafından
Yorum Ekle
try to find out whats wrong with it and get that fixed
Puan 0
Yorum Ekle
Yanıtını ekle
kris sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 418
