Ana içeriğe geç
This instant film camera, also known as the Neo Classic, was released by Fujifilm in Fall 2013 under the model number 16404571. It is silver, and comes with the choice of black or brown accents.
My Instax Mini 90 photos have these weird purple dots
So I’ve recently got an Instax Mini 90 Neo Classic and I got it in a pack (which had the camera straps and 3 packs of 10 of film). I used the film and I took a photo and it printed out with these purple dots.
I’ve cleaned the lens and the two holes near the lens (I forgot what those are called). I took another photo yet it still had the purple dots.
I don’t know if it is the film causing the problem or the actual camera itself. If anyone has been through this problem before and knows how to fix it or has an answer, please tell me.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
It’s probably the camera
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Some of the chemical used in film may have leaked out and gotten on your rollers. You can simply use a little bit of cotton or a Qtip and go over them with some rubbing alcohol.
Source: http://www.forgottencharm.com/trouble-sh...
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thank you! But, does an Instax Mini 90 have rollers that I could clean? Because I can’t see them :(
tarafından
It might be inside the cartridge on this model. I can’t find a reference image or video showing the exact location. If there is a roller in the camera, it will be behind the slot that delivers the photos. Clean that slot, also.
If that doesn’t work, have you tried a different cartridge in it? It is possible the issue is still some of the developer has leaked, but is being applied to the photos upon removal from the cartridge. Also possible is that the roller marks are from a machine in the factory which loaded the sheets into the cartridge (defective cartridge).
tarafından
Yorum Ekle
Ok so I bought an insta x mini 9 got it from amazon i took a couple pictures and it work and i took a picture and all this purple ink and green ink are coming from the bottom and it all white and i read a blog about this before and it say that expose to to much sun light so i went in a dark room took my picture shake it and the same thing happen again now i dont know what to do please help i would really appericate it rn.
Puan 0
1 Yorum:
please someone help
tarafından
Yorum Ekle
You probably have some kind of substance on the camera rollers. The dots are caused by contamination making a "bump" on one of the rollers which is pinching the film everytime the roller rotates - like a lentil stuck on a rolling pin. You'll need to clean the rollers, preferably with Isopropyl alcohol on a cotton bud.
Puan 0
Yorum Ekle
Yanıtını ekle
Kathleen Ges sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 3,713
