Ana içeriğe geç
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
CPU Upgrade from i5 3.4 GHz to i9-9900k?
Hello Guys.
I need some help, I bought 27” iMac 2017. Which has Intel 3.4 GHz i5.
But my question is, is it possible to upgrade to i9-9900k or i7-9700k?
I would like to know if I can and I don’t want to damage my system.
I appreciate your comments, thanks.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Simple Answer not possible!
The i9 CPU’s use a different socket (high heat) and the systems EFI (BIOS) doesn’t offer the needed firmware support.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Could you tell me which CPU could be work for that iMac? Thank you for your answer.
tarafından
The top CPU in this series is the 4.2 GHz i7-7700K
iMac "Core i7" 4.2 27-Inch (5K, Mid-2017)
tarafından
i7 7700k and i9 9900k share the same LGA 1151 socket. Probably it wouldn't work due to EFI restrictions or something.
tarafından
Yorum Ekle
If you are in the SF Bay Area and have the CPU, I can rebuild the firmware. This is not rocket science. Man made machines should have ways to make them work. Never say no without giving a try.
Puan 1
Yorum Ekle
Yanıtını ekle
lopezclever sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,695
