Can anyone HELP identify this? Transmission shifting problem
A mouse has done a number on my parked 2000 Beetle 1.8T and I am in need of some guidance. I drove it briefly last week and quickly noticed an automatic shifting issue; the car wont change gear while accelerating, only after letting off the gas and even then only after about 10 seconds. The check engine light appeared soon after and I returned to my garage. My OBD2 scan tool spit out a P0722 Error code and after a quick inspection I discovered a wire inside the engine compartment hanging loose. I can’t seem to identify it… Some similar forums and how to videos suggested a transmission speed sensor could be the culprit but that appears to be intact. Attached is a photo of the problem and the mangled plastic connector I removed to help I.D. it. Any help would be appreciated. I am hoping to order a new connector and splice it back in without a costlier diagnosis. Thanks again. KP
Bu iyi bir soru mu?
