Ana içeriğe geç
Clicky Mechanical Gaming Keyboard - Fully Programmable and 5 Macro Keys. First released in 2010.
12 Soru Tümünü görüntüle
The keyboard lights up but the keys do not type or do anything.
The keys light up and when I click them the lighting effect changes but the keys do not type.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 22
7 Comments
when you have issues whit your keyboard whit a lot of keyboards when your keyboard doesnt respond to anything and the caps lock is lighting up its locked try to find the manual if you dont find how to unlock it its basecly just fn + windows key or there is a lock on if still not work fn + esc 3 sec and factory restart and it works so tadaaa
tarafından
My gk61 is doing something where on alt, fn, and the number row light up and no keys will register I need help. Also when I click control the key R lights up but it doesn’t do anything
tarafından
My Havit multi-function Backlit keyboard HV-KB558CM keyboard led works but my keys dont pls help
tarafından
GUYS please help me i have a logtech keyboard it is the logtech g910 whenever i plug it in only half the keyboard lights up but it lights up then turns off and lights up then turns of not the keyboard the color turns off my keyboard is not blutooth btw and the keys only work when the light is on i tried everything i tried the water imerssion trick and it dident help. You guys are my only hope the fate of my gaming carreer rests on you guys.
tarafından
okok just listen dont use water for any keyboard you numbskull
tarafından
2 tane daha yorum göster
Yorum Ekle
15 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You need to:
unplug the keyboard from your pc/laptop
then press and hold esc and M5
then plug it back in (while holding the keys)
then release the keys
and ta-da
Bu yanıt yardımcı oldu mu?
Puan 29
29 Comments:
dude i literally just made an account to tell you, thank yoou this worked for me wtf lmao.
tarafından
I've spent 8 hours trying to solve this. checked on youtube and googled with no results.
This solved it immediately! : D
Too bad I next beat the chit from keyboard in all the anger ...
tarafından
my keyboard doesnt have m5
help
tarafından
THANK YOU SO MUCH! I made an account just to say this
tarafından
Mine doesn't have M5 key too, please help
tarafından
24 tane daha yorum göster
Yorum Ekle
  1. Unplug the Keyboard.
  2. Press and Hold the Escape button (Esc), and Caps Lock (Caps)
  3. Plug in the keyboard to a USB port
  4. Release all keys
This solution is for windows users.
Puan 15
21 Comments:
Thank you, this worked
tarafından
This actually helped me so much after like 10 hours of trying to fix it thank you
tarafından
F**king genius. Thank you SOOO MUCH!
tarafından
Didn’t help.
tarafından
This did the opposite of help, my keyboard does not work anymore because of this... It is stuck in a loop of pressing the button ”TAB”... Do not try this
tarafından
16 tane daha yorum göster
Yorum Ekle
For cynosa keyboard the combo is Control, Esc, Caps
Puan 4
4 Comments:
dude i made an account just to thank you, i &&^&^$^ love u so much (no homo doe)
tarafından
Made an account just to say thank you so much bro. I’ve been trying to fix this for so long.
tarafından
don't work why?
tarafından
Fukjing genius THANKS !
tarafından
Yorum Ekle
You need to:
If you don’t have M5 just press M3 or M2
Puan 1
5 Comments:
I don’t have any m keys, but I fixed it
tarafından
Did the esc and other buttons... it installed drivers, said everything was good to go. It also shows up as a keyboard hid (human interface device) in device manager. Back lights work and change color with press of button. Not a single key besides the lighting effect work at all. My nephew asked me to see if i could make it work for him. I have no clue as to its condition or if it worked previously. But given it lights up and shows as keyboard and loaded drivers..... one would be inclined to think it would work. So far none of these solutions have actually been a solution for me.
tarafından
FN + Space bar fixed it for me
tarafından
Fn + Spacebar works for me.
If you are having this issue please be patient and try out all the suggestions here cause some might just worked. Thanks for sharing and helping me out
tarafından
Yorum Ekle
the keyboard might be in bluetooth mode, check the manual
Puan 1
Yorum Ekle
My keyboard has a key combination that when pressed locks the keyboard. Look up a command list for your specific keyboard and see if it has a lock command, this is what fixed it for me
Puan 1
1 Yorum:
Bruhhhhh. Soo easyyyyyyyy xdddd
Thank You man! I could see a Lock Button on F9.
I pressed Fn+F9 and TADA! It's working. I am really grateful to you <3
tarafından
Yorum Ekle
Depending on your model, the keys might be different
https://mysupport.razer.com/app/answers/...
Visit the above razer support website to find your keyboard key combinations.
Puan 1
1 Yorum:
This helped me, thank you :)
tarafından
Yorum Ekle
you have accidentally gone in to custom programming mode. fn+~ to get out of it
Puan 1
1 Yorum:
THANK YOU SO MUCH I just made an account just to thank you!
tarafından
Yorum Ekle
hey kenneth,
it is very possible that you computer doesn’t recognize the keyboard as a keyboard see in device management if the keyboard shows up. if it doesn’t show up you might want to see if you can download and install drivers for it.
https://www.razer.com/synapse-2?_ga=2.92...
if it doesn’t show up as a keyboard grab anotherone and install razer synapse it helps with most software related device failures.
good luck
-M
Puan 0
1 Yorum:
Mine shows up in device manager and everything lights up, but it doesnt type, its 60%
tarafından
Yorum Ekle
Have u checked the device manager as suggested by martijn?
it is a good idea to provide with more information. Like what happened before the problem. For example pc was working fine yesterday, this morning when i turned it on the problem shows up.
Try to use an external keyboard but first
If you are on windows 10 and can still get to the desktop do the following if the mouse still works. At the bottom on the left side on the taskbar left click on the window. A windows will open and on the left side close to the bottom choose the second bottom up (like a wheel)(just a highlight will show setting). On the windows that opens all the way down choose Update & Security. On the next window on the left side choose, Recovery and on the right side choose restart now. After the pc comes back choose Trouble shoot and next screen, choose advance options and then choose start-up settings and click “restart”, when windows come back choose number 4 (safe mode). If the keyboard works after that then i will say ur pc is infected or the driver for the keyboard needs to be re-installed.
On windows 7 after the pc is turned on and after the logo start tapping on the F8 key and choose safe mode the rest same as above
If u still have same problem now use the external keyboard in safe or full mode. If the keyboard works fine the internal keyboard is bad.
P.S. I could give you more tips (or other ways to check your keyboard) but that requires more technical knowledge.
Puan 0
Yorum Ekle
My gk61 is doing something where alt, fn, and the top row lights up. Also when I press control R lights up but it doesn’t do anything. I need help.
Puan 0
1 Yorum:
Did you manage to solve your problem?
tarafından
Yorum Ekle
Why is my razer huntsman mini keyboard work only on games but when I try to text it dosent work
Puan 0
Yorum Ekle
My rgb keyboard and mouse lights up but no num lock light nor caps lock light and it's not working
Puan 0
Yorum Ekle
Unplug the keyboard
Press and hold
Esc and Caps lock
Plg the keyboard back
Restart your
Puan 0
Yorum Ekle
I have a k530 red dragon fresh out the box. The rgb lights turn on but the keyboard it’s self is unresponsive please help
Puan 0
Yorum Ekle
Yanıtını ekle
Kenneth Paul Richburg sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 114
Son 7 gün: 792
Son 30 gün: 3,368
Her zaman: 134,513
