Ana içeriğe geç
HP 15-r137wm TouchSmart, 15,6 inç LED arkadan aydınlatmalı yüksek çözünürlüklü dokunmatik ekrana sahip, dördüncü nesil Intel Core i3 işlemcili bir dizüstü bilgisayardır. 6 GB RAM ve 750 GB sabit sürücü içerir. HP 15-r137wm TouchSmart, Windows 8 ile birlikte gelir. HP 15-r137wm TouchSmart model numarası 15-r137wm'dir ve bu numara dizüstü bilgisayarın alt kısmında, bataryanın altında, en sağ köşede bulunabilir.
Keyboard Zif separated from MB
I have accidentally separated the keyboard Zif connector on my HP 15-n230sa laptop from the main board. Didn't realise the tab was on the opposite side of the connector and stupidly prised it off the board.
Please would you mind taking a look at the pictures and tell me whether this can be rectified? Is there anyway to reseat it back on the board?
Resim
Resim
Thanks in advance!
Bu iyi bir soru mu?
Puan 0
1 Yorum
I will find some who can re-solder this for me. Thank you very much for answering my question, much appreciated.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
You are very lucky! The solder pads didn’t get damaged so it should be possible to re-solder the connector back down.
Now the tricky part! To do this right you need a re-work system which uses hot air. Your best bet is to find someone local to you with the needed tools to remount it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
go to hit shows on utube, the fellow speaks mostly indian, but if you watch he cuts plastic to fit over the end of the ribbon and a small piece for tension on the underside and heats them and then inserts them and they hold solid.
Puan 0
Yorum Ekle
Yanıtını ekle
Andrew Hawker sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 445
