Repair Predator FPV drone.
Started using a new Predator.  Had a small hard or crash landing.  Now I cannot get equal or consistent power to all blades.  I’ve repeated the set up process several times but only get power to 1, 2 or 3 blades, not 4.  Then, the 4th blade turns a little but not consistent. What may the problem be?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
if it is the same blade every time, perhaps the motor axis is bent or the blade itself is broken
tarafından Paylaş
Can I fix that and how
tarafından Paylaş
try to spin the fourth and the third for example motors with your hand then compare the force that you applied between them.
tarafından Paylaş
Yorum Ekle
