Ana içeriğe geç
The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
45 Soru Tümünü görüntüle
91 Honda Accord radiator fan.
Have a 91 Honda Accord that the radiator fan come on when you first crank the car and it stays on continuous while car is running and after car is off. If anyone has any info on this it would be much appreciated.
Bu iyi bir soru mu?
Puan 0
1 Yorum
And if the relay is ok what would be the next place to look?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@adunlap21
check the temperature sensor which acts as a switch to turn the fan on at a certain temperature. It is possible that it has failed and stays closed. You did not tell us the exact model or engine size of your Honda so you will have to check for the location of the sensor. It is usually located by the thermostat housing. Follow the top host going to the engine block to find it. Once found you can simply check the sensor with a multimeter set on resistance.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Comments:
The temperature sensor on car is new that is what leaves me puzzled. It’s a 91 Honda Accord with a 2.2 engine.
tarafından
In that case the next suspect would be the fan relay
tarafından
Yorum Ekle
Hi @ mrsmith271983
There is a fan timer way up under the dash that goes bad often on these cars.
(click on image to enlarge for better viewing)
Puan 1
Yorum Ekle
Yanıtını ekle
Archie dunlap sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 38
Her zaman: 1,712
