2010 mac mini best ssd
best ssd for 2010 mac mini
Bu iyi bir soru mu?
You might want to consider swapping out your optical drive for a second drive (SSD in this case). Here’s the IFIXIT guide Mac mini Mid 2010 Çift Sürücü Kurulumu. Here’s the needed parts iMac & Mac mini Dual Drive Enclosure and [bağlı ürün eksik veya kapalı: IF107-142]
Or, you can swap out the HDD for a SSD following this guide Mac mini Mid 2010 Sabit Disk Değişimi and you’ll need this kit [bağlı ürün eksik veya kapalı: IF171-043-3]
Ürün
$19.99
Kılavuz
Zorluk:
Orta
55 minutes
Kılavuz
Zorluk:
Orta
1 - 2 hours
Bu yanıt yardımcı oldu mu?
The “best” ssd’s are probably the Samsung 870 ssd’s but the 2010 mac mini uses sata 2 for the ssd connector which means that even if you get an awesome ssd, it’s not going to change the performance that much. I think a cheaper Crucial BX500 is best for the 2010 mac mini and can be found for less than $30
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 1,176
