Ana içeriğe geç
Repair and troubleshooting guides for the Acer Aspire V3-571G-9686. This 15.6 inch laptop was released in October of 2012.
Green line in right side of the display.
Hello. I own an Acer Aspire V5-571G laptop, with IPS LED Display, 1080p resolution. Suddenly, a vertical line has appeared in the right side. It changes the color, on white is green, but on black it is not visible. Do i need to replace the display or maybe is just the connector?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Răzvan Alexandru
well, test with an external monitor /display to confirm the lines is on your laptop display.
you can try reaseating the LVDS cable and see if it helps.
what you are seeing line … most probably the lcd display bonding on your laptop display is not well bonded.
you can try stripping till you see the lcd module, and try applying light pressure to it.
sharing a video, fyi.
https://www.youtube.com/watch?v=UNf81Z-i...
imo the video is a short temp fix.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Răzvan Alexandru sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 287
