Ana içeriğe geç
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Soru Tümünü görüntüle
Soru Kapandı
interchangeable logic boards
Hi There, this is Paul from Australia!! I have a PowerBook G4 Aluminum 17" 1 GHz.... I have broken the track pad ribbon connector on my logic board. My question is, can I purchase the PowerBook G4 Aluminum 17" 1.67 GHz logic board and put it in my computer? Thank you for your time....I love your site!!!
Best from Down-under!!,
Paul Gurry
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Unfortunately, just about every part for the 1.67 GHz machines are different.
You could conceivably go as high as 1.5 GHz, if you replaced the following parts:
  • logic board (obviously)
  • lower case
  • DC-In board
  • Sound card
  • PRAM/USB board
  • Heat Sink/Fan assembly
  • PC/Airport Card Cage
  • PRAM/USB cable
  • Modem Cable and Modem
  • DC/Bluetooth cable
However, that would be an expensive proposition. Sorry for the bad news!
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Hi Ben, Thanks for your help with this!!! time to throw the powerbook on the scrap heap I think..... It did work with an external keyboard but now the ribbon connector is totally broken I can't power it up!! Can you think of any other way I can power up this powerbook... I've tried an external usb keyboard with a power button with no luck! thank you again, Paul
tarafından
Well, I normally wouldn't suggest this, but if you're throwing it away anyway....
How handy are you at soldering? The reason I ask is because there are two metal pads on the logic board (about 1 inch above the notch that the upper case cable feeds through) with the writing "Power Button" to the right. You could try soldering a wire to one, another wire to the other, and installing a switch between these 2 wires that could hang out of the computer...
But that's all I got...and it's not much :)
tarafından
Hey Ben, Thanks for that tip! your a champ mate!!! I'll give it a go!!!! Cheers, Paul
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 908
