Ana içeriğe geç
The Surface Laptop by Microsoft is the first full laptop in the Surface lineup. Released June 2017. Model number: 1769.
33 Soru Tümünü görüntüle
Bottom of screen popped out. Something inside must have repositioned.
My Surface Pro 4 is working fine. There is about a 1/4” gap at the bottom of the screen as it has become separated from the unit. There appears to be a bulge inside somewhere keeping me from forcing the screen back to the bottom so the glue can set. I can’t seen inside. I have ordered the iOpener / Toolkit. What will I find inside?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Can you post a picture? It’s easier to tell.
The screen may pop out due to bent case, internal stress or swollen battery.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
toughest part of this laptop is you have to tear down the keyboard using a knife as the screws are found below keyboard of the laptop as stated in ifixit Microsoft Surface Laptop Teardown
Puan 1
2 Comments:
There is no integrated keyboard with the Surface Pro 4.
tarafından
Check the guide for tearing down for surface pro 4 system Microsoft Surface Pro 4 Teardown
tarafından
Yorum Ekle
Same issue with me and it’s the swollen battery. Using the generated gap it’s much easier to separate the screen and then either to replace the battery or puncture the film of the swollen battery so that it recovers the original shape. If done within one day just place the screen over the original adhesive tape and voila.
Of course not recommended to puncture the battery but was OK for me for emergency use (take care not to overheat the battery during charging and better than breaking the screen) and then replace when new battery was available.
Puan 1
Yorum Ekle
Yanıtını ekle
Ray Franklin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 1,124
