Ana içeriğe geç
Sony Computer Entertainment tarafından üretilmiş bir oyun konsolu. PS4 olarak da bilinir. İlk olarak 20 Şubat 2013'de duyurulmuş ve 15 Kasım 2013'te satışa sunulmuştur.
How to fix Eject sensor?
I recently purchased a used ps4 that has an issue with the eject sensor/button. The system reads and ejects discs just fine as long as I do it through the menu. So my issue is just the button or sensor. The power button and sensor work perfectly fine. Does it need a new button or could something be disconnected? Any help would be great!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You most likely have a model where the button is touch sensitive. In this case it’s usually either the metal spring that connects the eject button to the eject daughterboard is broken or bent. If it’s bent the wrong way you can bend it back so that it touches the eject board.
If it’s broken though you’ll need to replace the bottom cover.
Bu yanıt yardımcı oldu mu?
Puan 3
4 Yorum:
That did the trick. Thanks a ton!
tarafından
Thank you very much. Worked 100%.
tarafından
Hello, i have tried this however i cant tell if the bit of metal is touching? Is there a trick or special shape the metal should be?
tarafından
B Wallace I'm wondering the same thing can someone help , I've bent it right down , I'm thinking maybe it's the ribbon connection or something .
tarafından
Yorum Ekle
Yanıtını ekle
Christian S. sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 2,810
