Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
No cellular reception - first course of action?
I have been handed a phone to fix which has no cellular reception, but connects to WiFi. What would you recommend would be my first course of action with this? What antenna should I replace? It has already been reset, so it isn’t a software issue.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try dialling *#06#, that should give in return the IMEI number..if you get nothing it’s a typical baseband fault that needs a microsoldering repair. If IMEI is there you may try to get a replacement lightning connector which has the main cellular antenna embedded, if it’s an antenna issue on your present lightning assembly with the new one you should have some at least some weak signal even if the dock is not properly mounted to the housing.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Thanks! I'll try that, and then comment back the result.
tarafından
Dialling *#06# doesn't return anything, so it is a baseband fault? How hard is this to fix for the microsolderer?
tarafından
@albert8181 It sounds like a baseband issue. I personally fixed a few but had some that didn't have anything to do with the usual edge faulty pads, in which case it may be very time consuming given the great number of BB related components. An experienced microsolderer shouldn't have major problems fixing the BB itself, if it's a secondary issue much depends on diagnostic skills and time available.
tarafından
Yorum Ekle
Yanıtını ekle
Albert Einstein sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 46
