Ana içeriğe geç
The Nokia Lumia 730 is a Windows phone released in September 2014. It features a 4.7 inch inch display with a ~316 ppi density and a 6.7MP rear camera.
7 Soru Tümünü görüntüle
Phone keeps rebooting constantly after being dropped in water.
I dropped my Lumia 730 (RM-1040) in a puddle of water, and since then whenever I try to boot it up, it boots up, works for a minute (doesn’t matter if I use it or not) or so and then reboots. I am able to charge the battery through a universal battery charger, and I can confirm that when the phone boots up and I can see the battery percentage. I have been able to do a factory reset and during the process (which took about 7 to 8 minutes) it never rebooted (if it got to the reset progress screen in time). The display and the loudspeaker have been replaced once, before this incident, but I had no issues with that that. I have no idea if I should try to repair this or get a second hand one, and I really would appreciate some advice. It’d be great if it were possible to pin the problem, fixable or not.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Any time you have liquid intrusion there's never an iron-clad guarantee of identifying a single problem and solution. The fact that you've continued to use the phone and charge it up means that additional problems could have been introduced.
The *right* way to solve this problem is with a full disassembly, cleaning, circuit testing, and microsoldering to solve the problem, but such a process would be more costly than buying a used/refurb phone on ebay.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
It may be toast. I dropped my old iphone 4 in dish water. Immediately pulled it apart, removed the battery and dried everything I could. I then got a bowl big enough to hold the phone in about the middle, then poured rice in the bottom, put the open phone in and covered it with the rice.(I used brown I guess any kid would work) I left it in there overnight and then put it back together. Who knows it may just work, it did for me that phone still works and that was 4-5 years ago. I know not a technical answer but I got lucky!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Rahul Baidya sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 132
