Ana içeriğe geç
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
Will not start spin cycle!
HE3 will not spin but will fill and drain. The wife says the tub area seems warmer than normal. Did the cancel cycle which did not change. The wife thoughjt there was and error code of ?6 but was just for a moment
Bu iyi bir soru mu?
Puan 0
1 Yorum
Did the diagnostic and it went to C08 then stopped. What do I do now?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
try this and see what you come up with. Let us know DIAGNOSTIC TEST The control must be in the OFF state before pressing the touch-pad sequence to start the test. Starting the test mode Close the door. Press the Control On button. Select the DRAIN/SPIN cycle. Select NO SPIN by pressing the SPIN SELECT button, as needed. Push Prewash Option button four (4) times within five (5) seconds. C:00 will show in the display. NOTE: If Model does not have PREWASH Mode as an option, press RINSE/HOLD. If the Starting procedure fails, push PAUSE/CANCEL button. Then repeat the starting sequence. Test Program Control during Execution To advance to the next step of the test procedure, push Prewash Option button two (2) times.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
jeff4949 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 1,914
