Why is my paper not feeding?
The printer will pull in the paper for about an inch and then stop & continue printing…on no paper. When it pulls in a little it wrinkles on the right side.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Here’s a video on how to clean the paper feed rollers on your printer:
Bu yanıt yardımcı oldu mu?
try running maintenance onto your printer… just open microsoft word, then click on file, next, click on print, then on the left side of it click printer properties, another dialog box appears, then go to the maintenance tab and you will see bottom plate cleaning and rolling plate cleaning, let’s see if it will work
Make Shure that the paper is being picked up by the guise wheels. If not open it up and check for foreign objects or paper Jams stuck in the way of the paper. Something as small as 4 grains of rice, positioned in the right way can stop everything.
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 43
Her zaman: 4,458
