Ana içeriğe geç
2015 yılında piyasaya sürülen Asus G752VL-DH71, 17 inçlik bir oyuncu dizüstü bilgisayarıdır. Genellikle daha kısa olan G752VL veya G752 isimleriyle anılır.
audio port broken needs replace?
My Laptop has a broken audio port. If I plug my headphones into the headset port only One side works of the two headphones. This applys also to all other headphones I can see the plastic circle where the headphones plugs into has missing plastic and clearly some damage to the plastic circle. I need to replace this part how much can I purchase this for and how simple is it to replace a damaged port?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
From what I can see of this teardown video for a similar laptop, it might have to be that you have to replace the whole motherboard if you want to do it simply. There is a possibility of soldering and replacing purely the headphone jack component, but that’s out of my expertise area and pretty hard as far as I understand. I also haven’t found this part online anywhere. You can obviously bring it to a repair shop, but it would be pretty expensive. The cheapest alternative is to get yourself a pair of USB/bluetooth headphones. I have a laptop with a similar problem (except that the jack doesn’t work at all) and use USB headphones that work just fine.
Carpe Diem,
Minas
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
BOB MARLEY sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 1,028
