Ana içeriğe geç
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 Soru Tümünü görüntüle
Unable to boot to usb?
I picked up this system (2008 macbook air) on ebay in hopes it would be a quick fix. It was shown to be displaying the folder with question mark which seems to be missing OS / hard drive related.
I’m an experienced IT professional but never got in to macs. I followed a guide at :
https://superuser.com/questions/383235/c...
and with an OS image downloaded from apple created a bootable USB. However, actually booting to it seems impossible.
If I boot holding option, it gives a wifi selection. No apple or globe icon.. just wifi selection and I can connect to my wifi. But then there’s no progress bar and it appears to be doing nothing. If I just power on with no buttons pressed it gets a white screen and then the folder with the question mark after a bit.
Could anybody help me figure this out?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
What system are you booting from and what are you trying to install?
tarafından
Do you have access to a second Mac system?
You might want to try just to connect the two systems in Target Disk Mode How to use target disk mode to move files to another computer that way you can access your Air's drive from the other system setting it up and formatting it.
tarafından
Thanks for the replies. It's model a1237.
I do have another mac I can try to connect it with later. I followed your link and am going to see if firewire > usb is possible since all the air has is the usb port.
Still stumped on how the system seems to be pretty much bricked with no avenue to enter bios or anything like what I'm used to with other systems.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
I have this issue also, there seems to be no good answer. I've been to forums and others seem to have this problem also. Seems to be older units more than newer. I have a dvd drive so I can load from disc. Go to mac rumors forum and see if anyone has found abwork around. Also you can use target disc mode if you have another mac. You may also be able to use an external hdd dock as mine will recognize that, it just seems to be the flash drives.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Brent Baucom sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 835
