Ana içeriğe geç
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 Soru Tümünü görüntüle
A 2.8v battery of Ipad Mini 1 still good?
Hey guyz how do I know if an old ipad mini 1 with 2.8v charged battery still good? The new battery reads 3.0v.in multimeter.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Depends, you'll need to charge it for quite a while to turn it on 3.7V is minimal voltage to boot an iPad up and 4.1-4.4V is maximum charge voltage for battery.
You can use 3Utools from 3u.com on a windows computer once you got the iPad on to check the battery health.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
If you have a Mac, you can use Coconut battery to check out your battery by using your charging cable and plug into a USB port. It has an iOS feature that will check both iPhones and iPads.
https://www.coconut-flavour.com/coconutb...
Puan 2
3 Yorum:
Ipad mini is dead
tarafından
Some kind of logic board problem i just thinking to reused the battery.
tarafından
You really don't want to reuse a battery you've pulled. You can easily cause damage during the removal process that would make the battery unstable in a new device.
tarafından
Yorum Ekle
If the battery voltage drops below certain threshold, it will lock out and refuse any charge, this is a safety mechanism by design.
However I’m not sure if 2.8 is the threshold or if there is anything else wrong with it.
Puan 1
Yorum Ekle
Just download a app that will tell you the health of your battery you don’t need to manually test the battery. Just search up battery life in the AppStore
Puan 0
2 Yorum:
I can't do that because my ipad mini is tottaly dead.
tarafından
tarafından
Yorum Ekle
Yanıtını ekle
judez mendoza sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 87
