Ana içeriğe geç
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
20 Soru Tümünü görüntüle
After water damage - LCD has no light
Hi,
The phone dropped into a toilet.
And immidiate got out, and been dried with a fan.
It was 1 week ago, and phone works fine but the screen is very dark, and it has no light!
I barely see the icons..
But the incoming/outgoing phonecalls are working, also the touch.
What is responsible for the Light in the screen? That could be damaged?
**Note:
  • Anyway I am going to open the phone now and make a water damage repair (Clean with alcohol etc)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
jea, clean it and the display connector ! should help very well. if not, you should buy a new display
cost 20 bugs.
Bu yanıt yardımcı oldu mu?
Puan 1
9 Yorum:
in a 3gs it is more likely the backlight coil if a good clean doesn't sort the problem out. that part is a 6r8 which will require soldering...
tarafından
Hi pollytintop,
I didn't understand what is: "backlight coil", and "6r8 which will require soldering"
I took out the LCD, cleaned the connector.. and still no light :/
I checked with another LCD, and the other LCD works fine.
Thank you for helping.
Shai
tarafından
Ok, Did you mean that the problem is in the backlight coil, and in order to fix it, I will have to solder it?
Can you please add a picture that shows where is that backlight coil?
Thanks again man!!!
tarafından
you've answered your own question. another LCD works.. so the problem isn't the backlight coil (which is on the motherboard) clean the LCD flex end and see if that helps. otherwise like ion said you need a new LCD.
tarafından
Yes - Another LCD works.
I did not know the coil is on the MB :-)
So..?
What about some coils/flex cables on the defective LCD? No option o fix it somewho?
Thanks
tarafından
4 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Shai sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 3,573
