Ana içeriğe geç
22 Eylül 2017'de satışa sunuldu. Model A1863, A1905 olarak tanımlanıyor. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Altın, Gümüş, ve Uzay Grisi renklerinde satılır.
iPhone 8 Home Button Really Sensitive
Hi,
I bought an iPhone 8 yesterday from gumtree, and the home button is extremely sensitive. If I touch it as if I was using Touch ID it ‘presses’ the button really quickly for as long as I hold it there. It thinks a light tap is a hard home button press.
I can use it to go home if I tap REALLY lightly. Touch ID still works.
Research shows it could be a couple things;
 - U10 Chip?
 - Bent flex cable
- Bad replacement screen
I have tried changing the tightness of the screw underneath the home button, which does nothing.
Thanks for the help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
The iPhone 8 does have a more sensitive home button. Just one more of those minor irritations that life likes to throw at us. You’ll have a more sensitive touch within a day or two!
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thanks for your answer but this is definitely not intended behaviour!
If i hold my finger on the button for 2 seconds as if to use Touch ID, the home button will be pressed about 15/20 times.
tarafından
Yorum Ekle
Yanıtını ekle
alim123 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 602
