Ana içeriğe geç
Device name is Jensen 3 speed stereo turntable. Model is JTA-230.
Tone Arm Skips / Turntable turns unevenly
1) The tone arm seems too lightweight and skips and skates over my records.
2) The turntable does not spin at an even rate. I am not referring to pitch control. I can clearly hear that the record is not playing evenly.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
sounds as if your anti skate needs adjustment, it should be almost the same as the counter weight adjustment , Also your belt should be replaced or if you have a direct drive it may be the motor speed adjustment or motor is malfunctioning there are manuals available on line
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thank you for your response regarding the JTA-230 Turntable. There are just too many problems with this product that should not occur with a NEW out-of-the-box product. I had high expectations for this product based on the customer comments on Amazon as well as the price. Unfortunately, I will be returning it. Perhaps there is a better product out there.
tarafından
i recently bought a dual 503 from used site for 100.00 works great ,most of all built right and use it daily unfortunately i fell for the cd racket and sold my old dual with records now kicking myself .best of luck
tarafından
Yorum Ekle
Sometime you need to clean and check or replace your needle with a new one. Built up dust on the needle or stylus can can this. Or it may need the needle or stylus replaced.
Puan 0
Yorum Ekle
Yanıtını ekle
Brant Casey sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 875
