Fans are spinning at highest RPM after disassembly.
iStat Menus shows the temperature sensor of GPU die is not working. It wasn't the case before disassembly. Where is that sensor located? I changed the thermal paste on GPU and CPU and replaced my HDD with SSD. But it is not an SSD related problem because when I plug back in HDD fans are still spinning at the highest RPM.
The reason was to replace HDD with SSD, renew thermal paste on GPU and CPU. I get this when I run diagnostics https://imgur.com/a/JaGzQPo
Update (01/27/2019)
Would you please check these images out and tell me if you see anything wrong?
Bu iyi bir soru mu?
