Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
2193 Soru Tümünü görüntüle
Home button not working after dock connector repalcement
I have just replaced the dock connector (and this corrected the problem of impossible shutdown of the phone) but now the home button is no longer functional. I am pretty sure it worked before. Any clue or suggested investigation before I commit to the difficulties of replacing the home button and/or home button flex circuit ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Thanks. I understand you mean the tiny ZIF connector that in in fact part of the dock connector assembly, and connects to the end of the home button flat cable. I suspected a problem here, reconnected the ZIF connector, but this did not help. I am going to try again, investigating the ZIF connector functionality more deeply, and if not, I guess I will have to consider replacing the home button flex circuit, which seems to be complicated and bears additional risks… On another phone, I have successfully replaced the power button circuitry, and made the button operational again, but now the upper loudspeaker does not speak… Correcting a problem often leads to creating another, just as is the case in the replacement of the dock connector assembly.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Check the small flex cable connector of the home button, that is connected to the dock connector flex cable you replaced.
Make sure it is secured in the connector.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Yves sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 50
