Ana içeriğe geç
Guides and support for various television (TV) brands and styles.
9064 Soru Tümünü görüntüle
Hisense 55R6E horizontal and vertical lines after changing main board.
I repair televisions. This is the second Hisense 55R6E that I have replaced the main board in. All precautions were taken. The unit would not connect to wifi but the picture was good. Replaced the mainboard and the wifi and the image had multiple colored lines running both vertically and horizontally. Put the old main board back in that worked previously (except for no wifi) and the lines remained.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi,
You have to check the T-con board flex cables, It seems like something wrong with your flex cables. try to clean it up and check whether your flex cables worn out. Hope this will answer your question.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Have you done much work on these models? I just got off the phone with tech support and they said the pictures I sent in looked like screen damage. I do not know how the screen could have been damaged during the repair. Plus this has happened twice…same model.
tarafından
Yorum Ekle
Yanıtını ekle
mysticus_tami sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,070
