Ana içeriğe geç
The Vtech Kidizoom Smart Watch DX was released by Vtech in August 2015. There are six different colors of the Kidizoom Smart Watch DX, but repair guides for all models are the same.
How do I get water out from the touch screen
My son wore his watch accidentally in the tub . I put it in a bag of rice but it still has water in the touch screen . How do I get it dry behind the touch screen ?
Bu iyi bir soru mu?
Puan 6
6 Yorum
Another way is to charge it and it will restart but to me, that is okay
tarafından
I tried and it did not work it is soaked inside and i am mad so if any one knows how please tell me
tarafından
Oh um same thing happen to me last night I put it in the tub but I forgot it was not waterproof so putting it in a bag of rice helps also use a hairdryer to dry some of the water it really helps but the best thing to do it but ti in a bag of rice but sometimes that does not work and charging it for me does not work also but if you have a different way please tell me please
tarafından
Ok so i found a way and it works to so While many Android Wear watches and Android phones are waterproof, this isn’t always the case. The iPhone and Apple Watch are two notable examples of devices that won’t take kindly to a dunk in the bath, puddle or, worse, toilet. And, be as careful as you like, but it’s all too easy to end up with a wet phone, wet smartwatch or wet activity tracker. It doesn’t have to be an expensive mistake, however. Here are several tricks that may help you to dry out a wet phone or watch.
tarafından
my watch has a sticky substance and i can not clean it how do i get rid of it
tarafından
1 tane daha yorum göster
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Drying things out in rice is a myth. It never works. The only thing outside of removing the touch screen is to put it upside down on an air vent or blow dry it. Dont use a lot of direct heat, but sweep back and forth. Hopefully the water in it wont roll around and damage any components.
Bu yanıt yardımcı oldu mu?
Puan 5
5 Yorum:
Am I able to remove the touch screen ? I have the back of the watch . If I remove the circuit board does the touch screen pop out ?
tarafından
On this model, Im not 100% sure. I would maybe try letting it dry using the methods above.
tarafından
Thank you so much , I dried out the watch on the floor register and it's working and all the water dried out from behind the screen .
tarafından
Youre welcome.
tarafından
This solution is the best. I had a fan constantly sending the air from the charger part and all the water dried out in 2 days. Thank you for the solution. You saved us! :)
tarafından
Yorum Ekle
I wasn’t able to get the water to dry out just from a vent or blow dryer. But this worked for me: You can warm it with a blow dryer to loosen the glue, then peel the front screen plate up, then do the same (warm and peel) to the digital screen glued to it, just enough to slide in a slip of paper or paper towel to pick up the water itself or spread it thinly so the blow dryer can dry it quickly. Press back together with glue still warm and everything should stick in place.
Puan 3
Yorum Ekle
That way did not work for me. My way is to charge it and it will restart but to me, that is okay. You will still have all your pictures, videos and game progress. But you do need to charge it for 1 and 1/2 days so that it is fully charged and so that it will not just shut down on you.
Puan 2
1 Yorum:
I am trying it, and I really hope it will work. The suggestion sounds good, though.
tarafından
Yorum Ekle
It been sitting in a box for 2 years
Puan 0
Yorum Ekle
Yanıtını ekle
Loreli Evans sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 137
Her zaman: 17,143
