model 721.86013010, f5 error code, humidity sensor,
replaced humidity sensor but error code remains, bad replacement sensor?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You did fine on replacing the humidity sensor.
The other cause for this code is the
Thermistor
Here’s the part:
LG OEM Part #6322W2A001A
Bu yanıt yardımcı oldu mu?
F5 code stands for Damper switch sensing error on Model no. 721.86013010 also for models 86012/86019 .
code errors for kenmore elite microwave model no. 721.86013010 and 86012/86019
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 2,901
2 Yorum
Thermistor changed, cleared F-5 error, relay clicks but no microwave power, noticed a fuse inside, could that be the problem now? Don't have time to take the cover back off to check the fuse right now.
sam tarafından
If i have the F-5 error code should I change out both the humidity sensor and the thermistor to be safe? anything else causing the F-5 error?
Bob Carpenter tarafından
