What does .AF mean?
When you push down the flash, it goes off but than it goes off AGAIN and the picture turns out as just a white blob. Why does the flash go off the second time?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Not sure about the .AF. It would depend where it shows up on your camera. I do believe that it shows that your Auto Flash is on. The double flash is done by your setup. For Red-eye The flash fires twice—once, then again when the picture is taken. So you should check your manual, available here,and see how to turn it off. I hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 4
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 662
2 Yorum
Laura Gross, just as a follow up, I was wondering if you got your camera working again.
oldturkey03 tarafından
Midway Island.
mayer tarafından
