Ana içeriğe geç
Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Soru Tümünü görüntüle
Dropped MBP - powers on, black screen, SMC reset doesn't help
My partner dropped her laptop. I have a Thunderbolt cable on the way so I can backup the disk using my laptop in Target Disk mode.
Does boot up. Apple logo and keyboard backlight do not come on. Display does power on, as I can see the difference in color between the display and the display’s housing.
Here’s what I’ve done:
  • flashlight test - can’t see anything still
  • SMC reset
  • boot to safe mode
  • unplugged display cable and plugged back in
Anything else I should try?
What can I check further with the display and the logic board, and which one should I replace?
edit: Plugged in my other laptop’s external display via HDMI and for some reason my partner’s MBP’s display is working now. Strange.
It does have some fragmentation to go with that, however. It flickers every now and then, and has lots of “static” in the background, typically only noticeable in dark colors. What part can I replace to fix this?
Bu iyi bir soru mu?
Puan 0
2 Yorum
Can you post a vid showing the distorted image on the screen Adding images to an existing question
tarafından
I was unable to get the video uploaded anywhere. It was taken with a Moto x4, so no surprise that it won't. I did, however, get it fixed.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Plugging into HDMI made the MBP’s display come on. It continued to flicker and show a static-like anomaly at the pixel level, especially noticeable in dark colors. However, the flickering and that “static” went away after a while. Everything is operating normally, even after a restart.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
David sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 89
